RB433AH and voltage monitoring via snmp
Because of the RB333 is replaced with the rb433ah now i try this routerboard.
I want to get the input voltage through snmp. With the rb333 it worked (see this post):
http://forum.mikrotik.com/t/rb333-voltage-in-snmp/16061/1
I am using os 3.10 on the 433ah board but the oid isn’t available any more. Does someone know which oid gives me the input voltage for the rb433ah?
For the rb333 this oid worked:
1.3.6.1.4.1.14988.1.1.3.8.0
I think that RB433 doesn’t support voltage monitoring.
If you try
/system health print
there is no info about voltage… on RB333 it is…
the 433 doesn’t have voltage monitoring but the 433AH has this feature. With
/system health print i can see the voltage, also in winbox: system health.
My problem is that the oid from the 333 voltage monitor doesnt work any more.
Thank you for the report.
Problem will be fixed in the next release.
since voltage monitor is essential for our sites on wind or solar power i just wanted to ask. is there a voltage monitor in the RB433AH than can be read in the same way than on the RB333 ? SNMP ruleZ !!!
regards
Jan
DEFINITIVE YES:
since 3.10 you can monitor the voltage with winbox (system/health) and in command lin (/system health print).
Since 3.11 it works with snmp. There was a bug before 3.11 so that snmp voltage monitoring didn’t work.
Hm, I tried to use SNMP for voltage montitoring with rb333, rb433ah, rb1000 with 3.20 and 3.22 fw, but the health oids didn’t work… does someone know why??
only the RB/333 , RB/433AH have an Volt Monitoring !
dingsingo
Can someone point me at the health oids? My snmpwalk doesnt seem to be finding them.
[user@ais-test] /system health> print oid
active-fan: .1.3.6.1.4.1.14988.1.1.3.9.0
voltage: .1.3.6.1.4.1.14988.1.1.3.8.0
