RB433AH as a switch/bridge
I would like to use RouterOS on a stronger server machine, not using the OS from the RouterBoard .. so
Server with RouterOS on it > RouterBoard (only as a switch/bridge) > clients
With this i will save the CPU/Memory usage on the RouterBoard so i can hook up more clients on the base station?
This scenario is possible?
Yes, it should work fine. This is a common set up by WISPs.
Tom
So…
I have routeros (as pppoe server), RB433AH (as access point). How to “bridge” wireless “incoming” connections to pppoe server?
