RB433AH as Access Point to RB450G
Hi all,
Just got a RB433AH to be a Access Point.
The RB433AH is connected to the main router (RB450G)
But Wireless is not working.
Have followed the steps on mikrotik wiki for wireless AP setup.
Have already enabled WLAN1 and set to ap bridge mode.
My laptops are able to connect to the AP.
But unable to access the internet and also to the AP IP address 192.168.88.3
On the laptops it says “limited connectivity”
I’ve change to wired connections to the RB433AH and internet works.
So i guess its my WLAN1 settings?
Please advise if theres are settings to change.
Additional info:
the main router RB450G is set at IP 192.168.88.1
The Access point RB433AH is set to 192.168.88.3
Sounds like perhaps you haven’t bridged the WLAN AP to the wired LAN or LAB Bridge - You will need to post more of your configuration.
Is 192.168.88.3 on an ethernet port, bridge or the WLAP AP interface?
