Hello.
I have a RB433AH configured to work as an edge router using BGP (full routes).
However, the 128MB of memory present on the board is not sufficient to store the entire routing table (approximately 711,000 routes).
Is it possible to use a memory card as an auxiliary memory to solve this problem?
If not, is there an alternative?
Will not work, you need a lot more ram. Get something like a rb4011 or rb1100ahx4 at a minimum.
Sent from my SM-A520W using Tapatalk
RAM will not be the only problem. With this much routes the cpu will get problems with forwarding.
True, and what I recommend was the minimum. Found i really like the rb1036 as a bgp router for multiple peering with full feeds.
Thank you all for your help!
Personally I see the 4011 as a SOHO device, my minimum suggestion will be CCR1009.
