RB433AH cannot upgrade routerboot
My RB433AH freezes between 3 days since new. But I want to make it usable. I’ve updated RouterOS, but I cannot upgrade routerBOOT.
Downgrade to 6.41 and update routerboot, then upgrade to 6.47.1 and update again.
If not work, try with other versions.
Regards.
Mikrotik has removed the archive from downloads. Is there any other repository for really old firmwares?
None of RouterOS images can upgrade my routerBOOT.
@normis?
Download from here: https://mikrotik.com/download/archive
I’ve tryied from 6.27 to 6.47.1. No one work.. :frowning:
Please create a supout.rif file, after a failed attemp to upgrade the Firmware and send it to MikroTik support.
