I’ve got 3 RB433AH’s that are all doing the same thing. Wondering if i might be doing something wrong.
They came with 3.23 but I’m trying trying to go back to 3.15. I formated and ran netinstall and installed the “routeros-mipsbe-3.15.npk” package. It appeared to be successful. It prompted for the reboot. Once it reboots it says “kernel failure.” It appears as if nothing got installed on the NAND. Tried different computers and nothing. Now i went ahead and installed the “routeros-mipsbe-3.23.npk” package. It appeared to install slower. One differece I noticed is a bunch of ###### going across the screen. Once i reboot I’m back running again.
Why can’t I install 3.15??? I even tried the 3.14 and 3.13 .mpk package and get the same results.
I have same issue, was not able to donwgrade RB-1000 that comes with 3.23 to 31.3, have to do it because the 3.23 has many issues, anyone know what is wrong? I tried Dude with force option, neither works, i know package is not corrupted, this have to be an issue on this version.
I also tried Netinstall without luck.
Mikrotik RouterBOARD 433AH with Atheros AR7161 680MHz Network CPU (overclock to 800MHz), 128MB DDR RAM, 3 10/100 ethernet ports with MDI/X, 3 miniPCI, microSD, 64MB NAND with RouterOS L5.
Supports POE on ether1: 10 to 28vdc on unused pairs (no power over datalines), or 10-28vdc power jack support. Overall dimensions: 150mm x 105mm (5.9in x 4.13in).
