rb433ah , Demo license expired! 4.6
Hello
The problem occurred after the upgrade from version 3.3 to 4.6 and did not do the key update
Get data cable + cable network + netinstall
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
Shutting down...
Stopping services...
Demo license expired!System halted.
Please reinstall the router.
and when i try to enter by making the ethernet port to boot this is what i get
and i can enter with netinstall as well
RouterBOOT booter 2.20
RouterBoard 433AH
CPU frequency: 680 MHz
  Memory size: 128 MB
trying bootp protocol........................................................................................................................................................................................................... failed
kernel loading failed
what should i do?
attached is the screen shot of the netinstall
Please help me
disable all firewall on the computer running netinstall during installing
disable all other dhcp or bootp servers in your network!
http://wiki.mikrotik.com/wiki/Netinstall
and reading documentation before acting could help…
ERROR: installation of routeros-mipsle-4.5 failed: broken package
Downloaded a new file
And the problem went
Thank you
