RB433AH DISK USAGE FULL?
Hi.
I have a RB 433AH for loadbalancing 4 upstream using mangle(nth) and mark routing(eth1). Also a route to proxy server (eth2). Distributing at ether3.
It seems somehoe the disk usage adds up very quickly (to 100%), while cpu usage and memory usage are at its moderate (25% & 34kb).
Is this considered normal?
While there’s no store on disk features activated.
I had this same setup using pentium 3 machine, with 128DOM v.310, but the disk never gets filled up, even with tools graphing store on disk were activated.
Rebooting the system will will only clear the disk usage to 30kkbps but then ads up to 100% within hours.
any idea?
 0   ;;; LoadBalance
     chain=prerouting action=mark-connection new-connection-mark=Modem1
     passthrough=yes connection-state=new in-interface=ether1_Distribution
     nth=4,1
 1   chain=prerouting action=mark-routing new-routing-mark=Modem1
     passthrough=yes in-interface=ether1_Distribution connection-mark=Modem1
 2   chain=prerouting action=mark-connection new-connection-mark=Modem2
     nth=4,2
 3   chain=prerouting action=mark-routing new-routing-mark=Modem2
     passthrough=yes in-interface=ether1_Distribution connection-mark=Modem2
 4   chain=prerouting action=mark-connection new-connection-mark=Modem3
     nth=4,3
 5   chain=prerouting action=mark-routing new-routing-mark=Modem3
     passthrough=yes in-interface=ether1_Distribution connection-mark=Modem3
 7   chain=prerouting action=mark-routing new-routing-mark=Modem4
     passthrough=yes in-interface=ether1_Distribution connection-mark=Modem4
 8   ;;; Proxy Load Balance
     chain=prerouting action=mark-connection new-connection-mark=Conn_PROXY-1
     passthrough=yes connection-state=new in-interface=ether2_PROXY nth=4,1
 9   chain=prerouting action=mark-routing new-routing-mark=Modem1
     passthrough=yes in-interface=ether2_PROXY connection-mark=Conn_PROXY-1
10   chain=prerouting action=mark-connection new-connection-mark=Conn_PROXY-2
     passthrough=yes connection-state=new in-interface=ether2_PROXY nth=4,2
11   chain=prerouting action=mark-routing new-routing-mark=Modem2
     passthrough=yes in-interface=ether2_PROXY connection-mark=Conn_PROXY-2
12   chain=prerouting action=mark-connection new-connection-mark=Conn_PROXY-3
     passthrough=yes connection-state=new in-interface=ether2_PROXY nth=4,3
13   chain=prerouting action=mark-routing new-routing-mark=Modem3
     passthrough=yes in-interface=ether2_PROXY connection-mark=Conn_PROXY-3
14   chain=prerouting action=mark-connection new-connection-mark=Conn_PROXY-4
     passthrough=yes connection-state=new in-interface=ether2_PROXY nth=4,4
15   chain=prerouting action=mark-routing new-routing-mark=Modem4
     passthrough=yes in-interface=ether2_PROXY connection-mark=Conn_PROXY-4
16 X chain=prerouting action=accept protocol=tcp src-address=10.10.10.1
     dst-port=80
17   ;;; Route Port 80 to Proxy
     chain=prerouting action=mark-routing new-routing-mark=PROXY_ROUTE
     passthrough=yes protocol=tcp src-address=192.168.254.216/30 dst-port=80
18   ;;; Mark Paket for Queue
     chain=prerouting action=mark-packet new-packet-mark=Modem1
     passthrough=no connection-mark=Modem1
19   chain=prerouting action=mark-packet new-packet-mark=Modem2 passthrough=no
20   chain=prerouting action=mark-packet new-packet-mark=Modem3 passthrough=no
21   chain=prerouting action=mark-packet new-packet-mark=Modem4 passthrough=no
22   chain=prerouting action=mark-packet new-packet-mark=Modem1 passthrough=no
23   chain=prerouting action=mark-packet new-packet-mark=Modem2 passthrough=no
24   chain=prerouting action=mark-packet new-packet-mark=Modem3 passthrough=no
25   chain=prerouting action=mark-packet new-packet-mark=Modem4 passthrough=no
Can you post the settings for the proxy? I’d guess it’s caching somewhere, because nothing else should use disk space like that.
/ip proxy export
:open_mouth: kindly help me with the PPPOE server setup and client?
Help!!!
dannaija: we’re not talking about PPPoE here, please make your own thread.
Thx.
But i finally reset the unit and it seems normal now.
I did suspect the proxy stored something without my knowledge :smiley: because i did use internal proxy with parent proxy, but disabled it has been disabled then.
Here is the proxy setting from my backup
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-drive=
system cache-hit-dscp=4 cache-on-disk=no enabled=no
max-cache-size=none max-client-connections=600 max-fresh-time=3d
max-server-connections=600 parent-proxy=10.10.10.1
parent-proxy-port=3128 port=8080 serialize-connections=no
src-address=0.0.0.0
