RB433AH Fan?
Has anyone successfully installed a fan in the RB433AH box? If so, what make and model did you use?
Thanks,
-tp
Greetings!
I use Sunon 40mm X 40mm X 20mm 12vdc fans. Careful about the power supply you use. The fan output is not regulated, so it gets whatever input voltage you are feeding the board. I use solar, so they get as much as 14.2 volts with no problem.
These will not fit in the Mikrotik indoor case. I use outdoor type cases.
