hello,
i am trying to upgrade the firmware of a RB433AH from 2.26 to anything above. if i do it within ROS with ‘system routerboard upgrade’ and reboot when asked it will not do it and still have 2.26. if i do it via serial console or netinstall it will give me ‘invalid upgrade file id’.
here the screen:
RouterBOOT booter 2.15
RouterBoard 433AH
Authorization: Passed
CPU frequency: 680 MHz
Memory size: 128 MB
Press any key within 5 seconds to enter setup
RouterBOOT-2.15
What do you want to configure?
d - boot delay
k - boot key
s - serial console
o - boot device
u - cpu mode
f - cpu frequency
r - reset booter configuration
e - format nand
g - upgrade firmware
i - board info
p - boot protocol
x - exit setup
your choice: g - upgrade firmware
Upgrade firmware options:
e - upgrade firmware over ethernet
s - upgrade firmware over serial port
your choice: e - upgrade firmware over ethernet
trying bootp protocol... OK
Got IP address: 192.168.1.20
resolved mac address 00:1C:42:DF:81:24
transfer started ....................... transfer ok, time=3.55s
your choice:
any help would be appreciated.
Thx
Jan
