RB433AH + R52H - multipoint link - best speed???
Hi there,
I have RB433AH with R52H card using b/g mode and 16dbi omni directional antenna with 20 clients connected to it.
What is the best speed i can acheave and is there a way to improve it with a new wireless card?
Clients are nanostation loco 2 and Edimax access points with Grid antennas.
Currently i can acheave a maximum of 11mbits…but it is not enough.
I need at least 20mbits for the moment. I want to evade placing other APs right now so i look for some improvement.
Cant use 2.4ghz-turbo and nstreme becouse of the clients devices.
Any suggestions?
Regards, Ventsi.
Nstreme is good for point-to-point links.
Reality doesn’t care for your needs.
Change the omni antenna to some directional antennas (sectors), seperate wireless interfaces each. Will work just fine, if configured right. Don’t use b/g, use g.
Hahahah,
Reality really doesn’t care :slight_smile:
I will install in addition some Nano M2 :slight_smile:
Just was curious if i can reach better speed.
Thanks anyways.
And btw…why is better to use g only?
You try talking to two people simultaniously in two different languages! :laughing:
If they support 802.11G and have connected via G mode, they should get around 30Mbit, if you have good signal.
Hmmm…thanks Normis… i will change it to G mode and will post later the result.
Hmmm…no improvement.
It seems that the best outgoing traffic from the wireless card is 11-12 mbits.
It is strange as i remember 4-5 years ago i used 2x Edimax APs on 5km link and managed to pass 16mbits ptp…i hope that the CPU of the board will handle the same traffic or better :frowning:
Anyways, thanks for the help.
I am gonna place another AP :slight_smile:
what is the signal level on both ends ?
It is PtMP link.
There are around 22*2= 44 ends :slight_smile:
