RB433AH+ROS3.25 PPPoE Server with Web Proxy Redirect
i have the following Problem.
Every 10-14 Days i have to reboot my RB433AH which is working as PPPoE Server (with UM) for approx. 100 Users with Web Proxy Redirect to an external Squid Box. The Customers said that the Webpages come very slow. All other Traffic is normal. If i disable the redirect rule the webpages comes normal again. Futhermore i have to disable the web proxy to login per winbox, without disableing i got disconnected every 5 - 7 seconds. I don´t see any changes/fixes in the changelog so an update might be useless.
After a reboot the Board works for 10-14 Days without any Problem?
Any tips?
I might be wrong but the only Version the Web Proxy works fine is 3.10 or 2.9.4x - 2.9.51?
thanks,
kabelfrei
at first, upgrade to the latest version, and check that you have ‘Max Cache Size’ set to ‘none’
But i dont see any changes for the proxy in the changelog? A other RB433AH ROS 3.22 with 15 Users online has no Problems with nearly the same setup. I will update on next week.
ip proxy print
enabled: yes
src-address: 10.x.x.x
port: 8080
parent-proxy: 10.x.x.x
parent-proxy-port: 3128
cache-administrator: "> support@kabelfrei.net> "
max-cache-size: none
cache-on-disk: no
max-client-connections: 600
max-server-connections: 600
max-fresh-time: 3d
serialize-connections: no
always-from-cache: no
cache-hit-dscp: 4
cache-drive: system
Some new observations:
After one day running the Free Memory is only 85 MiB and shrinks permanent. After a reboot the Free Memory is > 100 MiB. The Total Ram used by Web Proxy is: 8 MiB.
thanks and with best regards,
kabelfrei
These values are to low for my opinion play with these values I have max-server-connections: 5000. for example.
