RB433AH wireless router mode setup
i am trying to setup and 433 as a wireless router. wlan1 that i want a DHCP server set to with eth1 as wan port with static ip.
ive set it all up and made sure masquearde rule is in IP> Firewall>NAT is set but still cannot get on internet through wlan. can ping intenet from Tools>Ping.
Please help. have tried on multiple boards with no success. seems to me its something simple im not doing.
Thanks…
So if I understand You
wlan1 - access point
ether1 - gateway
I guess You know how to configure wlan1 interface…
  • IP > Address - there You can add your external IP on ether1, and some local like 192.168.1.1/24 on wlan1 for DHCP.
  • IP > Routes - there You must add route to Your provider 0.0.0.0 → gateway ip
  • IP > DNS - click on Settings and enter Your isp dns servers and check “Allow Remote Requests”, then OK
  • IP > DHCP Server - click on DHCP Setup choose Interface wlan1, then Next … Next … to the end…
  • IP > Firewall > NAT - click on + then under General tab enter Src. Address: 192.168.1.0/24, Out Interface: ether1, then under Action tab choose Action: masquerade, than OK.
That would be all…
ive done this same thing on 3 boards now but no success. only had left out the DNS thing and didnt add IP info on IP NAT. But tried it and still no success.
i cannot understand this. ive done this a few other times with no problems.
anything else to try?
ive tried this on 3 boards now with no success…
only thing i hadnt tried was putting the ip info on IP>NAT. tried that and still no luck.
also did the DNS thing and same results… I am out of things to try.
I have even reset and tried again. does anyone have any other answers?
Maybe some can login remotely and check my setup or ask me what to post regarding my setup… any help would be appreciated.
Thanks.
