Hi There
I have 2 x RB433AH’s with dual XR5’s in each, 20m up a tower. It runs from battery/solar power. I monitor the battery voltage daily and thats always stable. The lowest voltage I get is 12.4V during night time. The power cable going up the tower is 2mm twin core cable, one for each router board.
The problem: Every x-days (random) I have a total shutdown on the tower. Thus, the routers does not start up again. They just shut down and stays dead!? Every time it costs me to drive up the mountain, taking off a battery terminal and putting it back on again. Then all is dead stable for the next y-days, until the next shut down occurs.
Its not lightning…
I’ve already tried running it on a 24V system - same problem.
I’ve also gone so far as to fit a 35V 10000uF capacitor on each board - still same problem.
I was wondering if it’s not maybe the RB433AH’s thats just not capable of supplying enough power to the XR5’s? Do I need RB600?! Heavy expensive.
Any ideas. This thing is really starting to make me tired.
Thx
