RB433AH with XR5. Are this comèpatible with each other?
I need to install an access accespoint point to multipoint with a RB433AH and to cover an huge area in a distance of 25 km but i cant realize that with R5H minipci. Can i use XtremeRange5 5 GHz on RB433AH router board? i need to know if XR5 5 GHz of ubiquiti is compatible on RB433AH?
Can anybody help me on this?
why do you think that you can’t do it with R5H? you probably can
I need to cover as mutch as possible and the R5H is only 320 mw. Using a XR5 we have 600mw. So more power more cover we have. If you think that with R5H i can reach 25km witch antennas do i use? Another question: It is possible tu use on RB600A four minipci R5H? I know that there are 4 slots but i want to know if the boarder can support 4 minipci * 350 mw each so the total is 1.4W.
thank you for helping
more power will only bring problems, you need better antennas. wireless basics
plus - R5H has better sensitivity
