I’ve been trying to use NV2 on this link, and with the new ‘fixes’ for NV2. This board seems to just die about every 48 hours or so. I’ve had it come back with a simple reboot, but I’ve also had it completely die on me.
I’ve left the autosupout.rif for you guys to check out. Maybe I have something wrong?
(Btw it might not be on NV2 currently, this is something we’ve been testing out)
How old is the unit? If it is very old, check the capacitors for buldging. Some of the older 433’s developed this problem, and would make them unstable after a couple of years.
Also, check to make sure your power supply is still good for supplying enough power to the board and the xr-5
The first board was a 2 year old board. The caps looks great!. The PoE with a volt meter is putting out the right voltage. The new boards is a brand new unit, actually just got it from our vendors 2 days prior.
Since replacing the boards it had dropped twice now in 48 hours, a mac-telnet radio reboot is what was needed both times to get the ethernet to start working again.
Crossing my fingers, we are on hour 27 right now, and no problems.
