RB433ah
i have get R OS 433Ah and xr2 card and run it as ap mode
i want to add anew access point TP-link501 on system
the problem is when i add access from registration menu and copy it to access list i try to connect from my labtop via tp-link but give me hotspot message mean that “mac is used”
this message is appear when another pci wireless card connect direct to mikrotik or through access i want to know which mode i shuld select in tp-link??(point to point,clinet,repeater,…) and what i must adjust in xr2 configuration ?
iwant tp-link run wired and wirless
note: i use 3.14 virsion and use hotspot and made acc.per mac=0 on it and try to add user(cards) in hotspot user with mac and without mac(try both)
DHCP server is enable and access only give ip to clinet only in universal repeater mode!!!
plz help me
can you make a drawing of your network diagram ?
Is that addresses-per-mac set to zero? I have not tried that, but the result should be nobody gets an IP. If you want to remove the limit, use “addresses-per-mac=unlimited”
hello all
xr2 is lan out 192.168.0.1/24
eth1 wan 192.168.1.10
router speed touth 192.168.1.254
eher2 is lan out 2 192.168.2.1/24
i install 2hotspot server without any problem
one in wirless xr2 and second in lan out 2 eth2
when i connect with labtop i see in hotspot host my labtop mac without any problem
when i connect TPlink 501 access point in any mode and try to connect again with my labtop i see Mac of access not mac of labtop so if i have 2 labtop i cant connet
how can i see only mac of user not mac of access
i set up my card xr2 as ap bridge
