hi guys i bought this RB433AH is now the problem is that I took the card from laptops lenovo x201 and put in mikrotik is now pd wireles we do not read the card, since the first time I do if at all possible with this wirelles card to work a little mikrotik I read on the net say that drivers should not have them but I can advice
Hi
Please review
http://wiki.mikrotik.com/index.php?title=Supported_Hardware
especially under the 802.11 section
I have had it before that if the cards are not seated deep enough that it could cause that issue.
You can also look under system IRQ and those areas to see if the card loads at all.
What RouterOS on the routerboard?
Don’t forget upgrade the bios to.
If that not work, some wireless cards are not compatible
You must use Atheros cards. No other one is recognized by MikroTik.
You can buy a R52nM card for about 30$, and it performs great, and you can use either 2,4 or 5GHz
Regards
