Any ideas, Im hanging out for them.
~2 months, I guess ėnd of May.
RB433 with USB?
Thanks Normis,
I will hold off until then.
433AH with USB
This baby would be a good platform for building a NAS.
Are you considering Gb ethernet for it?
Or will the possible bottleneck for fast pushing of large amounts of data be elsewhere?
Would work even better for USB T1 cards and ext storage for CALEA, Proxy, Etc…
Hint Hint… ![]()
You can stop “hanging out”.
They are shipping now. Ours arrived today.
Tom
Are there indoor cases available?
EDIT
It seems there is.
http://www.roc-noc.com/product.php?productid=215&cat=0&page=1
We are shipping those with the CA/333 case. The USB solution today is to run USB cables out the N connector hole.
http://wiki.mikrotik.com/wiki/RB433UAH_indoor_case
Mikrotik will release a modified case in the next month or two with a larger cutout for USB access.
Tom
Got two in today…
Works GREAT !!
Connected A Sprint card, USB drive and GPS module, and all are happy..
(Used a powered USB HUB to offload some of the draw fron the USB port) it is rated at up to 2A but why tax it… when a powered hub is only 15$ us..
Will be putting it thru some more testing !! but do far, so good !!
Sounds great!
Wich USB GPS ??? It´s that possible ??? ![]()
I did use a USB GPS on x86 hardware, no problem… just as long it’s output is NMEA data!
Sorry been away for the holiday…
(Some holiday… I have a serios case of plummers bytt from all the sinks and toilets I fixed !!)
Any how… The USB GPS is AMBICOM GPS-USB…
Works great… (Not the MOST sensitive for indoor… but outside is fine.)
