RB433UAH Info
Hi:
A couple of questions:
  • Does 433UAH supports Atheros 5211 based cards? Or like 411AR it does not?
  • Where can I find an user manual or at least the fence connectors pinout? I only found the 433UAH brochure.
  • I installed an 1GB micro-sd card to serve as web-proxy storage. Next step will be a 2GB USB memory stick to be used as Dude files repository. Are this files acessible later via ftp or any other means? Since most of DNS requests are logged by my Dude config (syslog+filters) from time to time I need to move this files to a virtual disk on the web. One file each 24h is generated. Actually with 15 clients on a test AP I have an 8 … 14MByte file a day.
Thanks.
