RB433UAHL (or RB751G-2HnD) + USB HDD + torrent daemon
Hi!
The tool that I would like to do the following:
Given the device’s USB port connected to an external hard drive (preferably NTFS file system, but if not you can meet some ext).
The external hard disk to the internal network, I would like to achieve through the mechanization of SMB (but also correspond to the FTP).
The device should run in a torrent daemon, which is the external HDD to work.
‘normal’ as a router should work with the device (about 10/5-os external network).
Fully use your home, your Windows environment. Destination to avoid having to go to a torrent of machine.
RB433UAHL primarily interested in, but may be considered even in the RB751G 2HnD-type as well.
Is it feasible?
Deleted because not related.
Thanks for the info
But I want a tool to solve. Currently, a TP-Link 1043ND (OpenWRT +) carries out this task, but this gets to be a little longer. Transfer speed is not interesting (enough for 6-8 MB), no data security.
I read through several forums already, and I asked experienced users, but unfortunately it looks that MT can not be solved with a torrent daemon.
I understand the argument. Probably bad I asked the question (sorry for bad english). The problem is solved, not a solution looking for him.
I am just as much interested in the ways I have outlined can be solved whether the MT basis.
Thank you for your help, that you are clearly not feasible based MT, is not supported.
