rb435G and bad blocks...
i’m seein bad blocks appearing in my rb435g every time i try to upgrade/downgrade ros version…
it only 17 blocks so far but… should i start to be worried?
anything below 100 bad blocks is completely normal.
Did you install microsd card into this routerboard ? If yes try to remove it and check behavior. I’ve found on my 493G once I’ve installed microsd card quantity of bad blocks increase during write operations to main nand.
