Rb435G and Rb8000 Gigabit w/ MT Gigabit poe question.
So i have two MT Gigabit poe injectors…
neither of them power either the Rb800 or Rb435G.
Im using a 24V Power supply with the 435 and a 48V power supply for the Rb800.
If i use a standard poe, they both power up and work fine at 100 megabit.
Do i have to have a gigabit device plugged on the other end of the poe injector before it will
power up?? i’m not understanding this.
Thanks!
-Brad
Okay, figured out the problem, i knew i wasn’t retarded!
Bad Gigabit MT Poe injector. :slight_smile: Wierd i could get a bunk one new.
Pulled out another new injector, fired both boards right up.
-Brad
