Has anyone worked out what cases they’ll be using for the RB435G?
Will end up having to get a misc case and modify it, from the looks
any outdoor case will fit it. why do you need to modify anything?
if you are talking about indoor, why do you need 5 sectors indoors
“any outdoor case will fit it” !!!
when you use the Mikrotik large outdoor case i think you need to use some extra “nuts and bolts” to find a space under the RB to use the extra 2 Minipci slot on it , its littlebet difficult but you should try it. ![]()
is it a problem that you need to use longer distancers under the board? this is to be expected.
Well, some of us don’t necessarily use all mini-pci slots, but prefer sockets incase one more more dies. I wanted the Micro-SD slot and the USB slots myself. ![]()
I did find this on a google search though…
http://www.i4wifi.eu/indoor-case-for-rb435g_d2537.html
Might be useful if you don’t like putting Routerboards on the pole at a 4 sector 1 uplink site.
Apologies if the thread is a bit old. ![]()
