I have RB435G for several years. It was bought as replacement for x86 and never was installed till recently when good old x86 died. I think it had ROS 4.1 but i didn’t try it with that version. I update it to 6.42.6 stable using NetInstall and update firmware, then i install 3 wlan cards (2x CM9 and R52H) and configure it. I made several reboots using Winbox and with power cutting off, everything was fine. I installed it and for several days there wasn’t power failures so i didn’t notice the problem.
Then i realized that each time power fails, after that it wont boot, on board leds are working but lan leds don’t or wlans. It is not accessible by mac address either.
Then i simply plug it off and return power jack back and everything is working as normal.
This is happening all time and now it becomes annoying.
Did anyone have similar problem and what was the solution?
