not sure on the RB44, but I’m not too impressed… I can only get one to work in any given system, as soon as I put a 2nd in, it won’t even boot. same thing for having any other NIC in the system. i can put in all the 3com, broadcom, or intel nic’s I want, but only 1 rb44, and then nothing else, the computer boots, but MikroTik ROS locks up at the screen where you should be able to login at, I’ve tested this with a few systems, same thing on every one of them.
The rb44 is essentially 4 network cards on one pci board, so it will show up as 4 ether ports. That thing you found for 14 dollers is just as it says…a network card with a switch, so it will show up as 1 ether port.
ehem,… of course I did read the specs if you can call that little text an spec…
but I wasn’t sure if it is four independent port or single or double port…
however what I’m saying is for isntance Routerboard 532 has 3 port already, right? why does it have to be close to this RB44 which is only 4 etherchipset that its price is not more than 5bucks? combining that may 50 bucks but 100? pffff
anyway becuase I wasn’t sure that it is four independent port I just bought my rb44 to do my work ASAPa
On the OS, it sees it as one card. Then you can plug any device into any of the four ports, like its a switch.
In other words, think of it as a five port switch, with one of the five ports being hidden, because it’s wired up to the network chip.. if that makes more sense. Kind of a weird device, but kind of cool.
it’s cool in some platform but right now I need 4 independent port because the mainboard doesn’t have more space for more port and I don’t want second box at this time.
