Anybody worked with this scenario as the card would not fit. Had to remove the Cover and was able to only use 3 Ports the other is covered.
Worked fine for me in an ITX Intel D945GSEJT using the mini-box case and riser.
how did you manage to place the rb44Gv . I had to remove the cover of the Machine it was a lenovo and in the end only 3 ports are usuable
The riser I used mounts the board horizontally instead of vertically: http://www.mini-box.com/I-O-shield-and-riser-card-for-D945GSEJT
Someone did mention in another post that this board is now EOL.
Intel is EOLing the board.
Mini-box is EOLing the riser and I/O assy. accordingly..
BUMMER !!!
