Hello, I have the cable modem attached to this via DHCP client. The port has the IP, the routes have been put in. However, I am not getting any TX from the cable modem, only RX. I know its something simple I am missing…
Thank you.
Thank you.
Please post /export compact
set 0 name=Office-network
set 1 name=PTP-to-H
set 2 disabled=yes name=PTP-to-E
set 3 disabled=yes name=PTP-to-A
set 4 name=Ent5-Suddenlink-1
/interface ethernet switch
set 0 switch-all-ports=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=H-IP-pool ranges=10.92.92.14-10.92.92.254
add name=E-IP-pool ranges=172.16.16.10-172.16.16.254
add name=Office-pool ranges=102.168.68.20-192.168.68.2
add add-arp=yes address-pool=Office-pool always-broadcast=yes disabled=no
interface=Office-network name=Office-pool
add address=192.168.68.0/32 interface=Office-network network=255.255.255.0
/ip dhcp-client
add default-route-distance=0 disabled=no interface=Ent5-Suddenlink-1
add address=192.168.68.0/24 dns-server=208.180.42.100,208.180.42.68 gateway=
192.168.68.1 netmask=24
set allow-remote-requests=yes cache-size=10240KiB servers=
/ip dns static
add address=12.165.234.132 disabled=yes name=tiamat.westweb1.net
add address=66.76.133.251 name=test.westweb1.net
add action=drop chain=forward comment=“Drop invalid connections”
connection-state=invalid
add chain=input comment=“Allow established connections” connection-state=
established in-interface=Ent5-Suddenlink-1 protocol=tcp
add action=drop chain=input comment=“Drop invalid connections”
add chain=input comment=“Allow related connections” connection-state=related
established src-address=192.168.68.0/24
add chain=forward comment=“Allow related connections” connection-state=related
add action=masquerade chain=srcnat out-interface=Ent5-Suddenlink-1 src-address=
192.168.68.0/24
/ip neighbor discovery
set PTP-to-E disabled=no
set PTP-to-A disabled=no
add distance=1 gateway=Ent5-Suddenlink-1
/system clock
set time-zone-name=CST6CDT
/tool e-mail
set starttls=no
You masquerade rule is for 192.168.68.0/24 and your pool is **102.**168.68.20-192.168.68.2. You can remove the src address.
You ip address is also wrong. It should be
add address 192.168.68.1/24 interface=Office-network network=192.168.68.0
Awesome! Thanks a million!
It was late and I was tired/frustrated. I knew it was a type or something simple.
Thanks again.
OK, so now I am taking the same setup from above and trying to load balance 2 cable WANs (they are both the same, 10MB by 2MB) using this method:
http://aacable.wordpress.com/2011/06/04/mikrotik-4-wan-load-balance-pcc-complete-script-by-zaib/
Both of the cable modems are handing out IPs in the same subnet with same gateway. So, I read that you can connect a router (cheap wireless router) to either of the WAN ports to make it work.
I cannot get it to go. Is there anything I need to do to the wireless router config to make this work?
It appears to be passing data only on one of the two WAN ports. But even still, web pages are painfully slow if they load at all.
If there is a different/better way to do this, I am open to try it.
Any advice would help much.
If it would help for me to post my config, please let me know.
Do you always get the same gateway from your provider?
yes. Right now it is dynamically assigned on both cable modems. I have 5 static IPs with the package (not using yet), but they also have the same gateway IP (for both modems).
Can someone please direct me to an example where this will work? I need load balancing for two WANs that are in the same subnet and have the same gateway.
Thank you.
OK, I am posting an export compact of my config. Perhaps someone can tell me what I am doing wrong:
set 1 name=PTP-to-H
set 3 name=Int4-Suddenlink-2
set 4 name=Int5-Suddenlink-1
add name=H-IP-pool ranges=10.90.90.14-10.90.90.254
add name=Office-pool ranges=192.168.68.2-192.168.68.20
add add-arp=yes address-pool=Office-pool always-broadcast=yes disabled=no interface=
add add-arp=yes address-pool=H-IP-pool always-broadcast=yes disabled=no
interface=PTP-to-H name=Wireless-network
add address=192.168.68.1/24 interface=Office-network
add address=10.90.90.1/23 interface=PTP-to-H
add address=66.76.133.250/32 disabled=yes interface=Int5-Suddenlink-1 network=
66.76.133.0
/ip dhcp-client
add default-route-distance=0 disabled=no interface=Int5-Suddenlink-1
add default-route-distance=0 disabled=no interface=Int4-Suddenlink-2
/ip dhcp-server lease
add address=10.90.90.0/23 dns-server=208.180.42.100,208.180.42.68 gateway=10.90.90.1
set allow-remote-requests=yes cache-size=10240KiB max-udp-packet-size=512 servers=
208.180.42.68,208.180.42.100
/ip dns static
add address=208.180.42.68 name=rdns01.suddenlink.net
add address=208.180.42.100 name=rdns02.suddenlink.net
add address=192.168.68.1 name=test.w.net
add action=drop chain=forward comment=“Drop invalid connections” connection-state=
invalid
add chain=input comment=“Allow established connections” connection-state=established
in-interface=Int5-Suddenlink-1 protocol=tcp
add chain=input disabled=yes in-interface=Int4-Suddenlink-2 protocol=tcp
add action=drop chain=input comment=“Drop invalid connections” connection-state=
invalid
add chain=input src-address=10.90.90.0/23
/ip firewall mangle
add action=mark-connection chain=input in-interface=Int5-Suddenlink-1
new-connection-mark=WAN1_conn passthrough=no
add action=mark-connection chain=input in-interface=Int4-Suddenlink-2
new-connection-mark=WAN2_conn passthrough=no
add action=mark-routing chain=output connection-mark=WAN1_conn new-routing-mark=
to_WAN1 passthrough=no
add action=mark-routing chain=output connection-mark=WAN2_conn new-routing-mark=
to_WAN2 passthrough=no
add chain=prerouting dst-address=74.193.252.0/22 in-interface=Office-network
add chain=prerouting dst-address=192.168.1.0/24 in-interface=Office-network
add action=mark-connection chain=prerouting dst-address-type=!local fragment=no
in-interface=!Office-network new-connection-mark=WAN1_conn
per-connection-classifier=both-addresses-and-ports:4/0
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=
!Office-network new-connection-mark=WAN2_conn per-connection-classifier=
both-addresses-and-ports:4/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn in-interface=
Office-network new-routing-mark=to_WAN1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=WAN2_conn in-interface=
Office-network new-routing-mark=to_WAN2 passthrough=no
add action=masquerade chain=srcnat out-interface=Int5-Suddenlink-1
add action=masquerade chain=srcnat out-interface=Int4-Suddenlink-2
add check-gateway=ping distance=1 gateway=Int5-Suddenlink-1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=Int4-Suddenlink-2 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=Int4-Suddenlink-2
add comment=“Leave this” distance=1 dst-address=172.16.16.0/24 gateway=10.90.90.9
/system clock
/tool e-mail
set starttls=no
[admin@MikroTik] >
These two lines have zero on all counters:
Any advice?
For your routes you will need to set your gateway to use a specific wan. For example if your gateway is 1.1.1.1 on ether2 your gateway would be 1.1.1.1%ether2
You will need to do this for each route for your load balancing.
