I was attempting to upgrade my RB450 from 3.22 to the 4.10, but also decided to erase all of the Files (in WinBox) before uploading the 4.10 .npk file. I erased all of the files, uploaded the 4.10.npk file, rebooted the router and now I can’t access it anymore.
I tried holding the reset button on boot-up, as well as the reset hole, but no luck. I also don’t have the serial cable to access the router.
I’m now having trouble accessing my RB450 with a serial cable:
I plug-in the serial cable into my laptop (or desktop), start HyperTerminal, select COM4 which is the port used, select no Flow Control, baud 9600 and connect my RB450.
Then nothing is coming up in the Hyper Terminal screen… I tried restarting, holding the “reset” button for 60 seconds… etc etc.
I never used the serial port, could someone please suggest what I’m doing wrong?
I bought a good USB-Serial converter, plugged-it into my Win XP laptop, installed driver, Windows sees this device on COM4. I tried using HyperTerminal and Putty… selected “no flow control”, speed 115200. Nothing shows up on the terminal screen.
be sure you have the correct COMM port selected. Depending on what USB port you have it plugged into it will be assigned a different COMM port number. Windows also has some default COMM port numbres for other things.
If you have the correct COMM port number, make sure the cable is seated properly.
