RB450 Capicitor replacment
I have a RB450 that had three of the 6.3v 560uF capacitors vent. I replaced them with some 10v 1000uF and it is now working. I was wondering if there could be any issues because of the new caps. They are the two closest to the CPLD and the one next to the CPU.
Those caps go bad alot on that model. I just replaced 4 caps on a bad 450. (The green caps). If you only replaced 2, the others won’t be far behind. As far as the replacement caps, those should be fine as long as they are a good quality. I’ve used caps with even larger uF difference, and have had no problems since.
