I’ve had an RB450 sitting on a shelf gathering dust for some time.
I’m having a great time installing RB750s ![]()
So I wondered what would happen if I configured four ports on the RB450 as a switch.
I set it up the same way as the default settings on the RB750 and it works fine for a couple of minutes. Then the unit just hangs.
Apart from the obvious - return it to it’s previous config - is there any advice that anyone can give me?
I’m running RouterOS 4.1
