I have a RB450 and I am having problems setting up simple queues. I have port 1 and port 2 bridged. Port1 is connected the switch and port2 connected to my internet feed. I have setup a queue on a client that is plugged into the switch but I see no traffic. I can torch the client in the queue and it shows packets passing. I was first running v3.6 and after it wasn’t working I tried v3.17 which is running on it now. The only setting that I have set are the ones under the “General” tab. Any suggestions would be greatly appreciated.
I suspect /interface bridge settings set use-ip-firewall=no to be the problem but I AM NOT SURE. Post some configs here. Post the entire config with the
tags (omit passwords).
