where did the years go by..hmm..oh well that aside I just had to wonder..
I was planning to buy these three boards soon
RB450Gx4
RBM11G
R11e-2HPnD
(plus the 24HPOW power supply from mikrotik as well)
and basically set up the rb450 as the default router, then set up the r11-populated rbm11 board to basically pass everything onto the rb450
the latter two boards shouldn’t be any problem for the poe-out port on the rb450 yes?
as if I understand right, on paper 24v 500ma equals 12w and the rbm11 is designed for 11w maximum but i’ll likely operate on less radio power as I don’t need great distance nevertheless
