I have same problem with RB450G ROS 4.16
It’s not reboot - it shutdown when you try to reboot it.
Good solution - downgrade to ROS 4.13
In downgrade process it will shutdown too, and need to unplug power.
More information is required about your problem. The best option is to report the problem to support (support@mikrotik.com) with the following information,
attached support output file;
console output after reboot command.
This is output from my RouterBOARD 450G, where RouterOS 4.16 is installed (the latest firmware is installed as well),
Reboot is from Winbox,
MikroTik 4.16
Sergejs_Switch Login:
Rebooting...
Stopping services...
Restarting system.
RouterBOOT booter 2.29
RouterBoard 450G
CPU frequency: 680 MHz
Memory size: 256 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
Starting services...
MikroTik 4.16
I have a 450G running 4.16. I experience the “crash on reboot issue” occasionally. I can reboot with no problem MOST of the time, but the common factor I notice is this:
Occasionally, when adjusting rules (mostly in ip>firewall>filter or >queue tree) in winbox, the window will freeze up. All buttons lock and only after a couple minutes (or minimizing and then maximizing winbox) does the window free up and will respond again. I usually close the window and re-open at that point.
The reboot into shutdown issue almost always happens if one of these window freezes has occurred during the router’s uptime. If no freezes have occurred, it tends to reboot perfectly.
Any new developments on this? I had a router do this tonight. 493G Running 4.16. Anyone have this happen with any other routers besides 450 series?
This is a big fear for me as a lot of my routers are half a days trip away.
I had a 450g do this a few weeks ago, I just thought I choose shutdown instead of reboot but now I think it was this issue. I have a extra 450G and i’m gonna try to reproduce it tomorrow. My routers that have had it happen are running OSPF and PPPoE server and some PCQ queues if that helps
Only this I have is log entries that show: “: terminating… - system is going to shutdown” when I chose reboot in winbox
45 min later I was at the tower in the cold power cycling it
