RB450 reset problem
i’ve work alot with mikrotik but i didn’t need to use reset hardware
Now i’m stuck in a reset problem
The router was working before.
I’ve try many combination (press button before or after poweron, and relese button after 3,5,10,15 sec) but after reset, when i connect LAN cable in eth 2-5 i don’t have link
In one of these case, i get the link and i see his mac with ip 0.0.0.0 (from winbox)
I can connect, but after 1-2 minutes the link is going down and it’s not working again (even i power off an power on)
any ideas is welcome
thx
RB450’s sometimes suffer from faulty electrolytic capacitors.
Look here -
http://forum.mikrotik.com/t/rb450-capacitors-problem/35257/1
