I`m currently running multiple Routerboards but one of them has issues while rebooting using software command (CLI of WebFig)
The router seems to reboot but the interfaces are no longer there, these are the last log rules
14:09:54 system,info,account user admin logged in from 192.168.112.52 via ftp
14:10:05 pptp,ppp,info pptp-out-to-crs2.dro2: terminating... - system is going to shutdown
14:10:05 pptp,ppp,info pptp-out-to-crs2.dro2: disconnected
14:10:06 route,ospf,info OSPFv2 neighbor 192.168.120.220: state change from Full to Down
14:10:06 ipsec,error policy install failed: proposal disabled: ipsec proposal VPN-vCloud (6)
14:10:06 system,info,account user admin logged out from 192.168.112.52 via web
14:10:06 system,info,account user admin logged out via local
14:10:06 system,info,account user admin logged out from 192.168.112.52 via ftp
14:10:06 pptp,ppp,info pptp-out-to-crs1: terminating... - system is going to shutdown
14:10:06 pptp,ppp,info pptp-out-to-crs1: disconnected
14:10:06 route,ospf,info OSPFv2 neighbor 192.168.100.250: state change from Full to Down
14:10:09 system,info verified multicast-6.40.4-mipsbe.npk
14:10:12 system,info installed multicast-6.40.4
14:10:12 system,info router rebooted
14:10:16 ipsec,error policy install failed: proposal disabled: ipsec proposal VPN-vCloud (6)
14:10:18 interface,info vlan15 link up
14:10:18 interface,info vlan6 link up
14:10:18 interface,info vlan110 link up
14:10:18 interface,info vlan40 link up
14:10:18 interface,info vlan111 link up
14:10:18 interface,info vlan112 link up
14:10:18 interface,info vlan250 link up
14:10:18 interface,info vlan115 link up
14:10:18 interface,info vlan60 link up
14:10:18 interface,info vlan140 link up
14:10:18 interface,info vlan113 link up
14:10:18 interface,info vlan116 link up
14:10:18 interface,info vlan600 link up
14:10:18 interface,info vlan117 link up
14:10:18 interface,info vlan131 link up
14:10:18 interface,info vlan132 link up
14:10:18 vrrp,info vrrp110 now BACKUP
14:10:19 vrrp,info VRRP: vrrp110 now BACKUP
14:10:27 vrrp,info vrrp110 now MASTER, master down timer
14:10:27 vrrp,info VRRP: vrrp110 now MASTER, master down timer
14:10:36 system,info,account user admin logged in via local
14:11:17 hotspot,error,info,debug failed to add simple queue for interface vlan131: std failure: timeout (13)
14:11:18 hotspot,error,info,debug failed to add simple queue for interface vlan132: std failure: timeout (13)
I can stil login using serial console but the ethernet interfaces seems to be down, print of the interfaces is not working (hangs)
[admin@crs2] /interface vrrp> print
[admin@crs2] /interface ethernet> print
The only solution is a power cycle of the unit
[admin@crs2] /system routerboard> print
routerboard: yes
model: 450G
serial-number: 33xxxxxxx
firmware-type: ar7100
factory-firmware: 3.22
current-firmware: 3.41
upgrade-firmware: 3.41
The unit is running 6.40.4
