RB450 switch
So I am still very new at this stuff
But I got and RB450 and i want to use it to act like a switch
so i got my pppoe modem into ether1… looks like this is working
then I need to make the four other ports to act like a switch…
i dont know how to do this..
can someone help me?
thanks in avanced
Paul Hebert
Like this?
that can’t be it… do i need do do anything else?
Either use the built in switch chip or make a bridge and add ether2 through ether5 to the bridge. Then assign an IP/DHCP Server/etc to the bridge.
We don’t use the switch chip, so I can’t give you much information on it. Using the switch chip has the benefit of not using the CPU to process packets between the LAN ports. Bridge has the benefit of giving you much more control because you can pass the traffic through the firewall.
Chose whatever one better fits your needs.
I thinks that what I have?
but the internet is not working on any pc is there something missing
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
comment=“” disabled=no forward-delay=15s l2mtu=1522 max-message-age=20s
mtu=1500 name=bridge1 priority=0x8000 protocol-mode=none
transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes comment=“” disabled=no full-duplex=yes
l2mtu=1526 mac-address=00:0C:42:54:8C:0C mtu=1500 name=ether1 speed=
100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0D
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0E
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0F
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“” disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:10
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=
“” dial-on-demand=no disabled=no interface=ether1 max-mru=1480 max-mtu=
1480 mrru=disabled name=pppoe-out1 password=MMFVDUQB service-name=“”
use-peer-dns=no user=prhebert
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s management-protection=disabled
mode=none name=default radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-sta-private-algo=none static-transmit-key=key-0
supplicant-identity=MikroTik tls-certificate=none tls-mode=
no-certificates unicast-ciphers=“”
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment=“” disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add name=pool1 ranges=192.168.2.200-192.168.2.254
add address-pool=pool1 authoritative=after-2sec-delay bootp-support=static
disabled=no interface=bridge1 lease-time=3d name=server1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment=“” name=default only-one=default
use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment=“” name=default-encryption
only-one=default use-compression=default use-encryption=yes
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment=“” disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set default comment=“” disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment=“” disabled=no instance=default name=
backbone type=default
/snmp
set contact=“” enabled=no engine-boots=0 engine-id=“” location=“”
time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-protocol=MD5 encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=300MHz enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no silent-boot=yes
/user group
add comment=“” name=read policy=“local,telnet,ssh,reboot,read,test,winbox,pass
word,web,sniff,sensitive,!ftp,!write,!policy”
add comment=“” name=write policy=“local,telnet,ssh,reboot,read,write,test,winb
ox,password,web,sniff,sensitive,!ftp,!policy”
add comment=“” name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy
,test,winbox,password,web,sniff,sensitive”
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto
horizon=none interface=ether2 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether3 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether4 path-cost=10 point-to-point=auto priority=
0x80
horizon=none interface=ether5 path-cost=10 point-to-point=auto priority=
0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set (unknown)
set (unknown)
set (unknown)
set (unknown)
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:66:3D:87:50:11
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.2.1/24 broadcast=192.168.2.254 comment=“” disabled=no
interface=bridge1 network=192.168.2.0
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.2.1/32 comment=“” dns-server=4.2.2.2 gateway=192.168.2.0
netmask=24
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set pppoe-out1 discover=no
set bridge1 discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment=“” disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
set pppoe-out1 queue=default
set bridge1 queue=default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all comment=“” disabled=no interface=all interval=0.2sec min-rx=0.2sec
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/store
add comment=“” disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set from=<> password=“” server=0.0.0.0:25 username=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=
yes interface=all memory-limit=10 memory-scroll=no only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
1.) You don’t have an IP set for the WAN interface.
2.) You don’t have a NAT rule set up to NAT/Masquerade the traffic out of.
3.) You don’t have a default route for the router to send traffic out of.
If your ISP is handing out IPs via DHCP, you can set up a DHCP client on the WAN interface to take care of issues 1 and 3.
I would also recommend setting a horizon=1 on the bridge ports, this prevents traffic entering one port from going out the same port.
Get those things in place and it will start to route traffic out to the internet.
do i need to setup a dhcp client… i do get an ip when my pppoe is connected
I’m not familiar with PPPoE, but you should only need number 2 set up then if passes down an IP and route. If you log in via WinBox and look at your IP addresses and IP route, does it list an IP address on the PPPoE interface and is there a route with a dst-address as 0.0.0.0/0 marked with a D?
Do you know if your PPPoE Client is connecting successfully to the server?
hey thanks bud I got it tp work…
I guess I replied to fast… its was working but for only the pc in ether 2…
i made some changes now my modem dont connect argh!!!
I don't get it...
why does my modem doesn't work in port 1...
like i plug it in port 5 it works... i plug in port 1 it doesn't
also is there anything missing except the nat/masquerade?
here is my setup
[admin@MikroTik] > export
jan/02/1970 00:11:12 by RouterOS 5.0beta2
software id = RFMR-UNW4
disabled=no forward-delay=15s l2mtu=1522 max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526
mac-address=00:0C:42:54:8C:0C mtu=1500 name=ether1 speed=100Mbps
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2
dial-on-demand=no disabled=no interface=ether1,ether5 max-mru=1480
max-mtu=1480 mrru=disabled name=pppoe-out1 password=MMFVDUQB
service-name="" use-peer-dns=no user=prhebert
set default authentication-types="" eap-methods=passthrough group-ciphers=""
management-protection-key="" mode=none name=default
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key=""
wpa2-pre-shared-key=""
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
add name=pool1 ranges=192.168.2.201-192.168.2.254
/port
stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=
default use-compression=default use-encryption=yes use-mpls=default
/queue type
sfq-perturb=5
5
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter="" redistribute-connected=
redistribute-static=no router-id=0.0.0.0 routing-table=""
set default disabled=no distribute-default=never in-filter=ospf-in
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=
default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location=""
/snmp community
set public address=0.0.0.0/0 authentication-password=""
authentication-protocol=MD5 encryption-password="" encryption-protocol=
/user group
add name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,sensitive,!ftp,!write,!policy"
add name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,sensitive,!ftp,!policy"
add name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff,sensitive"
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=1
interface=ether2 path-cost=10 point-to-point=auto priority=0x80
interface=ether3 path-cost=10 point-to-point=auto priority=0x80
interface=ether4 path-cost=10 point-to-point=auto priority=0x80
no
set (unknown)
set (unknown)
set (unknown)
set (unknown)
default enabled=no keepalive-timeout=60 mac-address=FE:7D:BF:8F:7C:F8
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 require-client-certificate=no
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
/ip accounting
add address=192.168.2.200/24 broadcast=192.168.2.254 disabled=no interface=
add address=192.168.2.1/32 dns-server=4.2.2.2 gateway=192.168.2.0
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip ssh
set forwarding-enabled=yes
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
/ppp aaa
/queue interface
/radius incoming
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
/routing rip
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
0.0.0.0 user=""
/system watchdog
100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535
/user aaa
[admin@MikroTik] >
So I got it to work with a bridge… the only thing left.. would be to set it to use the switch chip
i really dont know how to do that
can someone help me with that???
thanks
Paul
If you’re using the bridge, don’t use the switch chip. If you’re using the switch chip, don’t use the bridge.
Switch chip doesn’t use the CPU so it saves CPU time to forward packets between end users, but you have very little control for the traffic.
Bridge uses the CPU, but you have control over the traffic, you can tell it to send bridged traffic to the firewall and use filter rules to block things.
So like I said I got it working with a bridge…
But there is something that a really don’t get… I got 3 pppoe modem on my desk
I know they are all working… but only one of them is capable of making a connection to the RB450
I got no idea why…
any one got an idea why its doing that
thanks,
PR
Try turning on PPP logging in the Mikrotik. If you go to /system logging you can add a source to the log, might want to exclude packets along with adding in PPP so you don’t get blasted with too much information.
Once the logging is turned up try and connect the modem to the Mikrotik and see what the log says. This should at least tell you if the modem is trying to connect to the Mikrotik and go from there.
So my boss want me to use the switch chip....
I think I setup it up like it suposed to be...
But the internet doesnt work
Need help
jun/18/2010 13:29:55 by RouterOS 4.10
set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes
100Mbps
"" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0D
"" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0E
master-port=ether2 mtu=1500 name=ether3 speed=100Mbps
"" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:0F
master-port=ether2 mtu=1500 name=ether4 speed=100Mbps
"" disabled=no full-duplex=yes l2mtu=1522 mac-address=00:0C:42:54:8C:10
master-port=ether2 mtu=1500 name=ether5 speed=100Mbps
/ip hotspot profile
use-radius=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des
add name=pool1 ranges=192.168.88.200-192.168.88.254
disabled=no interface=ether2 lease-time=3d name=server1
/port
stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption
add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment=
"" dial-on-demand=no disabled=no interface=ether1 max-mru=1460 max-mtu=
1460 mrru=disabled name=pppoe-out1 password=MMFVDUQB profile=default
/queue type
sfq-perturb=5
5
set default as=65530 client-to-client-reflection=yes comment="" disabled=no
set default comment="" disabled=no distribute-default=never in-filter=ospf-in
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=
/snmp
/snmp community
/user group
add comment="" name=read policy="local,telnet,ssh,reboot,read,test,winbox,pass
word,web,sniff,sensitive,!ftp,!write,!policy"
add comment="" name=write policy="local,telnet,ssh,reboot,read,write,test,winb
ox,password,web,sniff,sensitive,!ftp,!policy"
add comment="" name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy
,test,winbox,password,web,sniff,sensitive"
no
set (unknown)
set (unknown)
set (unknown)
set (unknown)
/ip accounting
add address=192.168.88.1/24 broadcast=192.168.88.255 comment=
"default configuration" disabled=no interface=ether2 network=192.168.88.0
add address=192.168.88.200/32 comment="" dns-server=4.2.2.2 gateway=
192.168.88.0
add action=masquerade chain=srcnat comment="" disabled=no out-interface=
pppoe-out1 src-address=192.168.88.0/24
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
/ppp aaa
/queue interface
/radius incoming
set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec
multiplier=5
/routing mme
/routing rip
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=America/Moncton
/system console
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=!pppoe
/system note
/system ntp client
0.0.0.0 user=""
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
/user aaa
for the modem… i am not sure if those logs can help you
but this is what I have
When i plug the modem that doesnt work (but doesnt work when its connected directly to a pc)
I get this..
13:33:58 route,debug,event Interface change
13:33:58 route,debug,event interface=ether1
13:33:58 route,debug,event status=UP,RUNNING
13:33:58 route,debug,event mtu=1500
13:33:58 route,debug,calc Begin calculation
13:33:58 route,debug,event Link up
13:33:58 route,debug,event Update
13:33:58 route,debug,calc End calculation
And when I plugin a diffenrent modem… but the exact same model mumber
I get this???
13:37:57 route,debug,event Interface change
13:37:57 route,debug,event interface=ether1
13:37:57 route,debug,event status=UP
13:37:57 route,debug,event mtu=1500
13:37:57 route,debug,calc Begin calculation
13:37:57 route,debug,event Link down
13:37:57 route,debug,event Update
13:37:57 route,debug,calc End calculation
13:37:59 route,debug,event Interface change
13:37:59 route,debug,event interface=ether1
13:37:59 route,debug,event status=UP,RUNNING
13:37:59 route,debug,event mtu=1500
13:37:59 route,debug,calc Begin calculation
13:37:59 route,debug,event Link up
13:37:59 route,debug,event Update
13:37:59 route,debug,calc End calculation
13:38:08 route,debug,event Interface change
13:38:08 route,debug,event interface=pppoe-out1
13:38:08 route,debug,event status=UP,RUNNING
13:38:08 route,debug,event mtu=1460
13:38:08 route,debug,calc Begin calculation
13:38:08 route,debug,event Link up
13:38:08 route,debug,event Update
13:38:08 route,debug,event Added candidate route
13:38:08 route,debug,event dst-prefix=0.0.0.0/0
13:38:08 route,debug,event attributes
13:38:08 route,debug,event protocol=DYNAMIC
13:38:08 route,debug,event distance=1
13:38:08 route,debug,event scope=30
13:38:08 route,debug,event target-scope=10
13:38:08 route,debug,event next-hop= address=10.0.10.254
13:38:08 route,debug,event origin-type=DYNAMIC
13:38:08 route,debug,calc End calculation
13:38:08 route,debug Begin redistribution
13:38:08 route,debug Accept 0.0.0.0/0
13:38:08 route,debug Commit prefix 0.0.0.0/0
13:38:08 route,debug End redistribution
13:38:08 ipsec @(#) racoon / MikroTik
13:38:08 ipsec @(#)This product linked OpenSSL 0.9.8l 5 Nov 2009 (http://www.ope
nssl.org/)
13:38:08 route,debug,event Address added or changed
13:38:08 route,debug,event local=142.166.111.177
13:38:08 route,debug,event network=10.0.10.254/32
13:38:08 route,debug,event dst-prefix=10.0.10.254/32
13:38:08 route,debug,event protocol=CONNECT
13:38:08 route,debug,event scope=10
13:38:08 route,debug,event target-scope=0
13:38:08 route,debug,event connected-net= address=142.166.111.177/32 int
erface=pppoe-out1
13:38:08 route,debug,event routing-mark=main
13:38:08 route,debug,event table=main
13:38:08 route,debug,event origin-type=CONNECTED
13:38:08 route,debug,calc Tag next hop for recalculation
13:38:08 route,debug,calc address=10.0.10.254
13:38:08 route,debug,calc Select route
13:38:08 route,debug,calc dst-address=10.0.10.254/32
13:38:08 route,debug,calc attributes
13:38:08 route,debug,calc protocol=CONNECT
13:38:08 route,debug,calc scope=10
13:38:08 route,debug,calc target-scope=0
13:38:08 route,debug,calc connected-net= address=142.166.111.177/32 inte
rface=pppoe-out1
13:38:08 route,debug,calc routing-mark=main
13:38:08 route,debug,calc table=main
13:38:08 route,debug,calc origin-type=CONNECTED
13:38:08 route,debug,calc Next hop resolved
13:38:08 route,debug,calc route=10.0.10.254/32
13:38:08 route,debug,calc immediate-address=10.0.10.254
13:38:08 route,debug,calc interface=pppoe-out1
13:38:08 route,debug,calc dst-address=0.0.0.0/0
13:38:08 route,debug,calc protocol=DYNAMIC
13:38:08 route,debug,calc distance=1
13:38:08 route,debug,calc scope=30
13:38:08 route,debug,calc target-scope=10
13:38:08 route,debug,calc next-hop= address=10.0.10.254
13:38:08 route,debug,calc origin-type=DYNAMIC
13:38:08 route,debug Accept add 10.0.10.254/32
13:38:08 route,debug Accept add 0.0.0.0/0
13:38:08 route,debug Commit prefix 10.0.10.254/32
On four modem i got two that connect to the RB450 and two that dont… I need everyone to work…
anybody can help me on my last two post
thanks a lot
under /ip dns don’t you need to change allow-remote-requests=no to =yes
for your client PCs to use your WAN’s DNS?
Are you able to ping from a client PC internet IPs but not names?
So I want to start from scratch…
So I want to use the switch chip instead of using a bridge…
Let me know if there something that is missing or i shouldn’t do.
So let say I do a system reset configuration…
then setup the pppoe connection on the ether1 and a get a connection
then I set ether3 , 4 and 5 to use master port ether 2
I put a dhcp server on ether 2 that use and ip pool
setup nat with masquerade
i am missing something
because I never been able to make it work using the switch chip
I try to change the DNS request to yes but that didn’t help
i must be doing something wrong i just don’t know what it is…
Thanks for all your help guys…
Paul-Rene
