rb450 to rb450g
hi all mik guru
my rb450g just arrived today for replacement of my old rb450 but how to upload my existing config from rb450 to new rb450g?
thanks
From the CLI
export file backup
(backup is the filename in this example)
Then copy the file backup.rsc from your files directory to your desktop.
Open it with a text editor and remove all MAC addresses.
Save it. Then you can drag it to the files directory on your RB450G and..
from the CLI
import backup.rsc
Tom
+10. Thanks Tom! Just received my rb450G from you guys to replace my rb450. These instructions are exactly what I need. Thanks a billion!
Grandma
