RB450G - 100% CPU usage
One from a lot of RB450G runing with 100% of cpu utilisation.
Is it hardware of software problem? How to disable health problem or
/system health print - shows nothing
/tool profile duration=5
NAME                    CPU        USAGE
console                 all         0.5%
flash                   all           0%
firewall                all           0%
winbox                  all           0%
management              all        27.5%
telnet                  all           0%
profiling               all           0%
health                  all          71%
unclassified            all           1%
/system resource print
                   uptime: 9m10s
                  version: 5.26
              free-memory: 245912KiB
             total-memory: 257108KiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 100%
           free-hdd-space: 481536KiB
          total-hdd-space: 520192KiB
  write-sect-since-reboot: 199
         write-sect-total: 262061
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB450G
                 platform: MikroTik
 /system routerboard print
       routerboard: yes
             model: 450G
     serial-number: 33B60288BFA7
  current-firmware: 3.07
  upgrade-firmware: 3.07
/system package print
Flags: X - disabled
 #   NAME                                      VERSION                                      SCHEDULED
 0   system                                    5.26
 1   ups                                       5.26
 2   routeros-mipsbe                           5.26
 3 X wireless                                  5.26
 4   routerboard                               5.26
 5 X ipv6                                      5.26
 6   hotspot                                   5.26
 7   advanced-tools                            5.26
 8   mpls                                      5.26
 9   security                                  5.26
10   ppp                                       5.26
11   routing                                   5.26
12   dhcp                                      5.26
Not sure about the health problem, but high management cpu usage is usually caused by snmp … try disabling snmp.
JF
JanezFord,
there is no difference between different SNMP settings.
I don’t know what in health would be using up 71% of the CPU.
Best answer probably come from a supout file (either looking at it yourself in the viewer or sending it to mikrotik) and get some real answers.
Regards
Alexander
I have exactly the same issues after upgrading from 5.14 to v5.26 on RB450G.
CPU usage today suddenly locked up at 100% without apparent reason. I had to reboot the device to get it working again.
HI
I have same problem. I have 163 queue in my mikrotik router. Is this any coz of this problem?
