RB450G/433UH
My English is not good, I had in some way search a similar problem
I am haveing some issue some time in both Rb
I was accessing remotely (over internet) the device and when I disable all the firewall to check if was the firewall blocking a WOL packet I loose connectivity to the device
To get connectivity I need to unplug the cable and put it again
Even if use the save mode this problem is not restored
Any one have some idea what can be ?
Some info:
Ros is 5.25
Wan is on eth1 That is connect to a small bussins Cisco switch
Since my device is down because of this problem I can’t give any more information on the device until tomorrow.
Raffaello
