Pretty strange issue here.
I’ve put ETHER2 as master-port for ETHER5 (=WAN PORT). After a reboot, ETHER2 fails to get a DHCP address from my ISP. When I disable and re-enable ETHER5, DHCP works. ETHER2 now obtains a DHCP-address from my ISP.
I’m not sure what I’m doing wrong here. Any ideas fellow Mikrotik users?
/ip dhcp-client
0 interface=ether2 add-default-route=yes default-route-distance=0
use-peer-dns=yes use-peer-ntp=yes dhcp-options=hostname,clientid
status=bound address=84.194.x.x/20 gateway=84.194.x.x
dhcp-server=195.130.x.x primary-dns=195.130.x.x
secondary-dns=195.130.x.x expires-after=1h44m9s
/interface ethernet> print
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 RS WAN 1500 00:0C:42:3E:57:A7 enabled ether2 switch1
1 RS ether1 1500 00:0C:42:3E:57:A3 enabled ether2 switch1
2 R ether2 1500 00:0C:42:3E:57:A4 enabled none switch1
3 S ether3 1500 00:0C:42:3E:57:A5 enabled ether2 switch1
4 ether4 1500 00:0C:42:3E:57:A6 enabled none switch1
[admin@MikroTik] /interface ethernet switch vlan> print
# SWITCH VLAN-ID PORTS
0 switch1 10 switch1-cpu
ether1
1 switch1 20 switch1-cpu
WAN
ether1
ether2
/interface ethernet switch port> print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 ether1 switch1 secure add-if-missing 0
1 ether2 switch1 fallback leave-as-is 0
2 ether3 switch1 secure always-strip 20
3 ether4 switch1 fallback leave-as-is 0
4 WAN switch1 secure always-strip 20
5 switch1-cpu switch1 secure leave-as-is 0
