RB450G - HDD Problem
Dear all
Kindly advise, i had RB450G currently show only 150 MB of Free HDD Space, i had do hard reset and remove old configuration but the problem still there, attached the screenshot
:laughing: cek winbox files. I think many files in your rb450G, web login etc. & remove. look at rb450G againt. :slight_smile:
I had remove hotspot file, but free HDD space remain only 150 MB, any help pls :frowning:
I want to know your winbox files..please screen shot files your winbox& your system packages list
Here is
wouwh…what happens?
I think sir Normis,sergej,janisk (mikrotik support) have any idea?
are you running user-manager?
I think, upgrade to V 5.7 with netinstall & check againt your resource in the winbox
look in System → Stores, it must be empty.
