I’m experiencing two issues, which I suspect are related.
I have two RB450Gs as follows:
RB450G 1:
- V6.2, FW 3.0.7
- Standard aluminum case
- Indoors in an air-conditioned room
- Basic config: Masq, DHCP, firewall, no hotspot/connection tracking
- ~10-20 users
- 15Mbps or less of WAN traffic at any given time
- 12V power supply, /system health shows 12.7V
- Average operating tempurature: ~70C at boot to 90C during CPU issue
- Unit is placed on top of a DSL modem
RB450G 2:
- V6.2, FW 3.0.7
- Indoors in a non air-conditioned room
- No users at this moment (lab setup)
- No/minimal traffic
- 25V power supply, /system health shows 25.4V
- Average operating tempurature: ~54C
- Unit is placed on top of a server in a rack
The issue I’m experiencing pertains to RB1. RB2 was purchased as a backup for RB1 and has virtually the same configuration, just no users or traffic. I’m using it as a comparison to troubleshoot RB1.
The problem is, RB1’s temperature runs significantly hotter than RB2, despite being in an air-conditioned room. It boots at about 70-72 degrees, which is fine, but over time, will climb up into the high 80’s to low 90’s. About that same time, the CPU utilization will go from 0-2% average that I’m used to seeing, to 100% solid. /tools profile shows 89%+ being used by “Unclassified” during this time. A power cycle or /system reboot resolves both issues for a few days or weeks, then resurfaces. I don’t currently graph CPU utilization or temperature on this box, so I’m not sure if it’s creeping up, or jumping up to 100% when the problem occurs.
Either way, the board temperature and the CPU utilization seem to be correlated; I would take that to mean the temperature is causing the CPU voltage to drop, causing a lower operating frequency and a higher utilization, but that doesn’t explain why a /system reboot would fix it as the actual temperature would be the same.
I guess my questions are:
- What’s the expected operating tempurature to be for the RB450G?
- Could the voltage of the PSU I’m using be contributing to the issue?
- Why would a reboot ‘solve’ the temperature problem (at least temporarily)?
