I got my hands on the new RB450G today. It looks like an awesome value. 680MHz Atheros AR7161 (MIPS big endian), 256MB RAM, 512MB flash (data sheet says 64MB), 5 Gig-ethernet ports, microSD slot (supports SDHC 2.0), and RouterOS level 4, all for $99!
I tested the microSD slot with a Lexar 8GB microSDHC card. It formatted and mounted just fine.
The boards shipped with ROS 3.21 which has a ‘store’ menu for the microSD card. There was also a ‘mesh’ menu that will be fun to play with on a RB433ah when they release 3.21.
The only negative that I found was that the master port assignment doesn’t work. I am hoping that it will be fixed/supported in future software releases.
Cool! I can’t wait to get my hands on one of those as well.
Shipped with ROS v3.21 you say? Is it not a GA version of RB450G you got, or are they distributing it with 3.21 before releasing that version for download from the website?
I guess RB450G will be a great box to run MetaRouter on aswell with its plenty of RAM (compared to the other RB4XX products). Was MetaRouter enabled on your device?
Don’t know the meaing of “GA version” but these are production RB450G boards that came with ROS 3.21 and 2.20 firmware installed. And yes, 3.21 is still not available to download from the MT website.
No metarouter yet. I am guessing that they needed 3.21 (or a new ROS version) to support the ethernet ports but metarouter probably was not ready for release yet.
GA=General Availability, ie available for the public.
[quote=“msundman”]
[/quote]
Sad, it says in the Wiki that Metarouter would be included in 3.21. And as it only ships with a Level4 license we can’t play with the 4.0beta
The bottom side of the PCB has the microSD slot and it does fit inside the indoor case with card installed.
(The slot is mounted under the smaller heat sink… you plug in the card from the edge of the board opposite the power jack).
There are also three other ICs on the bottom side center of the board. They are either flash or RAM chips.
I’m guessing it’s the ethernet drivers but this board is performing worse than the 493AH with 10/100 ports. Running a TCP btest to a 493AH shows 93Mbps while the same test to a 450G shows 58Mbps.
Please describe your test setup. What is your host device running to the RB450G and what ports are connected?
I suspect that things will improve with ROS 3.22 which is supposed to be released on Monday. I’m excited to try out the ethernet stats command that I saw in the changelog posted in another thread. I am hoping that it finally shows us ethernet errors.
I too am experiencing slowness. Same speeds as stated in the above posts.
I tested using Btest on port 2 which is a switch master. Same results if it’s not a switch master. Anyone have any ideas? This is kinda discouraging.
OK thanks, i actually hoped the Gigabit Ports would allow for Jumbo Frames like the RB600 does, but then again - that 450G still does more than one would expect for the price
Hi all! I work at home and need to be pretty much connected to my work via PPTP VPN constantly. I used to have a router that could act as a PPTP client, a Netopia R910, but I sold it long ago, plus it’s LAN side was only a 10Mbs hub. I’ve been searching around for a consumer router that can act as a PPTP client, but haven’t had much luck.
I was thinking about buying a used Cisco 1711 off eBay, but I haven’t been able to find convincing evidence that it can in fact act as a PPTP client (everything I’ve found says that it might work but it’s unsupported).
I need to have the PPTP connection dialed on demand when traffic is detected to certain networks (192.168.2.x, 10.20.10.x), or to just keep the PPTP connection up all the time, and reconnect immediately if it goes down for some reason.
I ran across MikroTik/RouterOS/RouterBoard in my Google searches, and this RB450G certainly looks like an affordable device that hopefully can do what I need it to.
So, my question to you guys is: can the RB450G act as a PPTP client, routing only certain traffic over the VPN link, routing all my normal internet traffic out my DSL connection directly? Can the RB450G keep the PPTP connection up all the time (or demand dial it), reconnecting automatically if it goes down?
I found out I may be able to get AT&T U-Verse DSL soon (18 MBit down, 1.5 MBit up). Since my last post, my work has also agreed to implement an IPSec VPN for me. Can the RB450G fully utilize that bandwidth? What kind of throughput can I expect to see on an IPSec AES tunnel while the RB450G is also performing firewall and normal routing duties? Would it be 10Mbit+ on the IPSec tunnel?
