We have about 10 network clients (desktops, laptops, smart phones, a printer, etc.) in our network (a simple home network shared among roommates). Two computers and one printer will be connected by wire and the rest wirelessly. I need Gigabit connection and it seems RB450G is the right choice if it had wireless connectivity or a mini-pci connector. Price-wise, it seems a good choice too.
So the solution can be connecting a wireless access point to one of its LAN connections. I am thinking to use my current router in access mode to provide internet connectivity to the wireless clients.
I am no expert by any means and I hope someone can confirm this will work. The reason we would like to go for a Routerband is to monitor and control bandwidth usage each client uses per a given time interval for example per day or in a month. My main question is with the wireless clients being connected to the network through an access point, would RB450G be still able to monitor and control how much each client is downloading/uploading based on its IP or MAC address?
If you were one of my clients, i would suggest the RB750 (max the 750G if the gigabit is really necessary), definitively not the RB450G (i would feel like stealing you).
Someone in this forum said: “..like buying a Mercedes 500sel, just for going to a 100m away store to buy a beer…”
raminux, you can control traffic on RB 750(G)/450(G) on that port where your AP is connected (ether2 to ether5) - you can do everything with traffic RB ROS can, but only with all trafic on selected port. To control each connection on your AP, use AP’s software for that purposes. Or buy dedicated RB AP hardware.
I had a simular need/want. I run 15 - 30 clients/devices. I have a RB450G (I did not want to upgrade if I needed more performance.) All wired connections are 1Gbps, and I use a well known rival to MikroTik for my Access Point(s) . Your off-the-shelf router, if conigured properly should suffice as an AP. With some modification to http://mum.mikrotik.com/presentations/US09/megis_qos.pdf You can monitor/control all clients (wired and wireless) via IP. Hope this helps.
