faced with a problem … I have a fast internet with 300Mbps bandwidth, but give only Mikrotik 100Mbps.Question for you guys, it is possible to access all of 300Mbps? ![]()
Look at the numbers at the bottom.
Hmm ok…as if that would make all the 300Mbps?
Refering to http://routerboard.com/pdf/275/rb450g.pdf you should be able to get a lot more. Still if you use a lot of connection tracking and firewall functions this would reduce your troughput. I’m wondering since you get 100mb if it could be a speed problem with the interface? Have you checked if the auto selection have selected 100mb instead of 1gb?
check with
/interface ethernet monitor ether1
From my router now.
[admin@xx.xx.no] > /interface ethernet monitor ether1
status: link-ok
auto-negotiation: done
rate: 1Gbps
full-duplex: yes
default-cable-setting: standard
Interesting…
My router write:
[admin@MikroTik] > /interface ethernet monitor ether1
status: link-ok
rate: 1Gbps
full-duplex: yes
But speed
And directly without the router
missing more than half ![]()
Mm.. are you sure that speedtest could give you a accurate measurement with such a good line? If you try with a computer attached to the line instead? Or turn of the connection tracking in the rb450g? Have you testet elsewhere? (some other speedtest or with ping speed against your providers router
) Have you tested the line for a periode with graphing or mrtg?
Nop,i`m using default config,but my router for now not happy with me ![]()
Maybe you need a new configuration?Please help me.
Edit:
w00t i upgraded to newest 5.9 version and all fixed ![]()
yeahhh love you mikrotik,all thnx for help ![]()
I have same u problem I use 6.37.1 version mikrotik 450g
I can use wan by mikrotik max is 100
but my modem wan can connect internet 200mb
can u help me
my email is neotonight@hotmail.com
please help thank you
Check wan connection, should be 1Gbps.
First, you should enable Fasttrack.
But even then I doubt if the RB450G can handle 300 mbit/s.
The CPU on this router is not very fast compared to modern routers.
I’m pretty sure it can route up tu 500mbps but I’ve never tested. I hhave one in the basemen in storage. May I’ll make time to test it with my 500/25mbps connection.
