RB450G not boot after upgrade
I have upgrade my RB450G from v5.2 to v5.5, after the reboot it gives a blue led and a peep
The network port are also give signal but I cannot connect anymore. Winbox show not any mac/ip.
1)I have tried to connect (serial) with Hyperterminal/Putty but not any info is showing.
2)Reset with powering on with the reset button beside the power jacket gives no solution.
Someone an idee?
(Is it possible to use Netinstall without de serial port?)
I found the problem about the serial port. I did not use the Nullmodem cable. Now I get the info on screen :smiley:
