RB450G PPPoE Chap not working
Anyone have a RB450G using PPPoE chap successfully? Provider supports it and works fine when using other (Tomato, DD-WRT) firmware.
what’s in Log?
PPPOE: initializing…
PPPOE: dialing…
PPPOE: authenticated
PPPOE: terminating…
PPPOE: disconnected
then repeats.. I suspect the MPPE isnt compatible or working.. i have it with encryption enabled and the LNS supports 40 or 128 bit (using auto)
does the mikrotik only do 56 bit? i cant see a setting to change it anywhere.
