RB450G Reboot after connecting to Linksys SRW2024P
I just noticed something strange with my RB450G, the device is fine for more then a year now. It is connected to my Linksys SLM2008 and running okay. Now i have foun myself a new switch (SRW2024P) and when i connect the switch al seems fine for a couple of seconds and then the routerboard reboots (leds off / beep). It makes no difference if i use ether1(poe) or ether2
Both switches are gigabit but the SRW2024P is a POE switch
It seems to be solved when i disable POE support on the switch using telnet, but the switch has the habbit of enabling POE after some time (reboot for example). It is strange to see the issue is also occuring on ether2
http://w0lt.com/?p=172
