I’ve got this problem on my first and ever new Mikrotik Router ,lovely 450G,but when i am connect with my Serial to USB,i’ve got scrambled text both on securecrt and putty ,
SecureCRT settings :
Putty settings :
My Serial to USB devices driver shown and working correctly as this screenshot :
i have seen things like that on older USB/serial-adapters, probably caused by the serial controller chip.
only solution i know is trying another adapter.
yes,i was tested the winbox and using the normal-files method to upgrade mikrotik,because of this seem causing some bad blocks(4) so i want to tried netinstall before RMA to my distributor.
yup after this morning i bought another more ‘branded’ cable,i’ve got a clear text ,thanks to everyone,cheers.
